[RESOLVED] Package contents in plain text in the waptdb.sqlite file
GF68
Registration: Oct 05, 2021 - 11:22
March 29, 2023 - 4:33 PM
I just noticed this morning that the contents of the local database file waptdb.sqlite is clear.
Full file path:
C:\Program Files (x86)\wapt\db
The entire contents of the packages executed on the machine can be read in plain text.
The problem is that the file can be read by all users.
Is this normal, or have I misconfigured my installation?
Guillaume
Server: WAPT Enterprise 2.4.0.14143 on Debian
Console: Windows 10
Infrastructure: Windows
March 29, 2023 - 4:57 PM
This is perfectly normal; our documentation explains it clearly:
https://www.wapt.fr/fr/doc/wapt-create- ... pt-package
Since session-setup needs it to execute the code located in that same database,
if you need to store sensitive information in a package, you must follow the example in the documentation.
GF68
March 30, 2023 - 08:36
Thank you for your reply!
I completely missed that part of the documentation.
Out of curiosity, why wasn't the file encrypted?
Console: Windows 10
March 30, 2023 - 2:36 PM
Hi Guillaume,
the `def session-setup()` function must be readable by the user when the session is opened, so it must be readable in a standard user context.
Regards,
GF68
March 31, 2023 - 11:03
Okay, I understand the logic better now.
Thank you for your reply.
Console: Windows 10
