Teams installation error message
Tom
Registration: Apr 20, 2023 - 10:17
April 20, 2023 - 10:41
Following the update of the Teams package that I downloaded from the WAPT Store, version:
tis-microsoft-teams 1.6.0.6754-67 x64 all windows
I'm getting an error on some machines regarding the status at the end of the installation:
Installing: Teams_windows_1.6.0.6754_x64.msi
MSI Teams_windows_1.6.0.6754_x64.msi already installed. Skipping msiexec
  File "C:\Program Files (x86)\wapt\common.py", line 4063, in install_wapt
  File "C:\WINDOWS\TEMP\wapt2ex0urlf\setup.py", line 55, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3840, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2138, in run
waptutils.CalledProcessErrorOutput: Command 'netsh advfirewall firewall add rule name="Microsoft Teams" dir=in action=allow program="C:\\Program Files (x86)\\Microsoft\\Teams\\current\\Teams.exe" enable=yes protocol=TCP profile=domain' returned non-zero exit status 3221225477.
Output:
Output:
The firewall is disabled on all profiles (see image Firewall_Profil.jpg).
The incoming rule already exists (see Firewall_Rule.jpg).
For your information, our WAPT server version is 2.2.3.
Thank you for your feedback
Sincerely
jpele
Registration: March 4, 2019 - 12:01
April 25, 2023 - 2:08 PM
are the affected machines running Windows 11?
Regards,
Jimmy
Tom
April 25, 2023 - 3:49 PM
Yes, the affected machines are all running Windows 11 22H2.
Regards
