some package groups cannot be edited
guestben321
Registration: Nov 30, 2021 - 4:38 p.m.
May 16, 2023 - 3:52 PM
I just realized that there are some package groups that I can't edit with my certificate and account.
It displays "Error when uploading package CheckPackageSignature
failed for Signer XXXXXX:,"
where XXXXXX corresponds to another user's certificate.
I'm not sure if my question is clear; do you have any suggestions?
Thank you!
WAPT Server Enterprise edition, version: 2.6.0.16552
May 17, 2023 - 3:29 PM
Hello GuestBen321,
WAPT version (see forum rules). Are you using an older version of WAPT?
Regards,
guestben321
May 22, 2023 - 2:42 PM
sorry, this is version Enterprise 2.3.0.13516
May 22, 2023 - 3:54 PM
Are you using an older version of wapt <=2.2, or are you launching the group editing via the command line?
guestben321
May 22, 2023 - 3:59 PM
I'm launching the edit via the GUI. WApt is version 2.3
May 22, 2023 - 4:12 PM
In the console, for the package in question, in the "Signatory" column, can you check if the signer is the same as the others?
Also, can you verify if the signer for this package is accepted (previous certificate in C:\Program Files (x86)\wapt\ssl on your machine)?
guestben321
May 22, 2023 - 4:25 PM
Indeed, the signing certificate name wasn't present in my C:\Program Files (x86)\wapt\ssl folder.
I just added the corresponding certificate to this folder and I can now modify the group.
Thank you, I finally have the solution to modify them!
But if I understand correctly, the admins who have the certificate I just added can now act on my machine?
May 22, 2023 - 4:35 PM
Yes, absolutely
To avoid this, you can do something else
In WaptConsole you can put:
public_certs_dir=C:\trust_cert
For example
guestben321
May 22, 2023 - 4:41 PM
I can't find where to put this setting. Is there a configuration file I need to edit?
May 22, 2023 - 4:42 PM
Directly in waptconsole.ini:
%appdata%\waptconsole\waptconsole.ini
