WUA error: No such file or directory
May 23, 2023 - 2:14 PM
That's strange, normally you wouldn't need to do that...
t.heroult
Registration: December 8, 2020 - 10:13 AM
May 23, 2023 - 2:34 PM
In any case, it's not coming from the antivirus; I'm not getting any feedback about it in the SentinelOne console...
Consoles: Windows 10 & 11
Infrastructure: Windows
t.heroult
May 29, 2023 - 3:20 PM
Update:
With version 2.4, this happened today on several machines (Windows 10 Pro).
However, this time the solution did not work.
t.heroult
May 29, 2023 - 4:29 PM
Here's the return to the console with version 2.4:
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 233, in GetModuleForCLSID
    __import__(sub_mod_name)
ModuleNotFoundError: No module named 'win32com.gen_py.B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0.ISearchResult'
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1910, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 276, in _run
    self.result = wua.install_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1335, in install_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 914, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 849, in updates
    search_result = self.update_searcher().EndSearch(search_job)
  File "C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateSearcher3.py", line 48, in EndSearch
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 96, in Dispatch
    return __WrapDispatch(dispatch, userName, resultCLSID, typeinfo, clsctx=clsctx)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 37, in __WrapDispatch
    klass = gencache.GetClassForCLSID(resultCLSID)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 180, in GetClassForCLSID
    mod = GetModuleForCLSID(clsid)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 241, in GetModuleForCLSID
    makepy.GenerateChildFromTypeLibSpec(sub_mod, info)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\makepy.py", line 319, in GenerateChildFromTypeLibSpec
    gen.generate_child(child, dir_path_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 1049, in generate_child
    self.file = self.open_writer(out_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 786, in open_writer
    return open(temp_filename, "wt", encoding=encoding)
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.13468.temp'
t.heroult
May 30, 2023 - 12:51
Indeed, when the previously mentioned command is launched, it only creates the gen_py/3.8 folder with only the __init__.py file.
If I copy the entire gen_py folder from the temp of an OK machine, it works.
