When importing certain packages, in this case Geany and Arduino, an error occurs and it is impossible to import these packages into our private repository. Here is the following error:
"Errors during package duplication: tis-geany_1.38-2_windows_PROD.wapt: THttpClientSocket.WGet: store.wapt.fr:443/wapt/tis-geany_1.38-2_windows_PROD.wapt"
The WAPT version is 2.2.3.12463 enterprise version.
The server OS is Windows Server 2019.
Do you know how to resolve this problem?
Thank you for your help.
Error importing packages
- WAPT Expert
some packages are protected and restricted for business users.
You can click on download here:
https://wapt.tranquil.it/fr/tis-geany/
You will be prompted to log in; you can then use the "forgot password" option
and import it as a file
