Range port TFTP
jdziadek
Registration: January 23, 2023 - 4:10 PM
May 12, 2023 - 3:28 PM
Hello, I'm following up on my last post about TFTP on WAPT.
For your information, we had indeed opened port 69, so the client was communicating with the server, but the TFTP protocol uses ephemeral UDP ports for the response, and these ports were blocked. :)
Once the ports were opened, it worked perfectly, however, the network administrator is a bit hesitant to leave the UDP responses open in "any" mode.
Is it possible to fix the TFTP ports somehow?
At the very least, what is the TFTP response range?
For example, on WDS, the ports used are 64001 to 65000.
Julien
Debian 11
WAPT Version: 2.4.0.14143
May 23, 2023 - 11:12
our developer made a commit to this effect in the core of wapt (mormot2):
https://github.com/synopse/mORMot2/comm ... b9305806f9
Version 2.5 of wapt (not 2.4) should therefore have the
jdziadek
May 25, 2023 - 6:26 PM
Great, thank you very much :)
Debian 11
