Hello everyone,
I'm having a problem with certificates when I try to add packages to my clients. To give you some background, I was using WAPT 2.2 with the console on a specific PC, but that PC crashed and I couldn't recover it. So I had to set up a new PC and install the console on it. I also took the opportunity to upgrade my server to 2.3.
I generated a new certificate when creating the new console and signed the upgrade package with it, but I can't deploy it to all my users.
Once the SSL file is copied to the test machine, it works again.
So my question is, is it possible to replace the certificate directly within WAPT, or do I have to manually replace it on all the machines (I have a lot of them)?
Thanks everyone.
[RESOLVED] The user certificate c:\path\certificate.cert is not authorized on the selection
- WAPT Expert
The mistake is here; you shouldn't regenerate a key during an upgrade. You should use the previous key you already have
https://www.wapt.fr/fr/doc/wapt-common- ... rivate-key
If you no longer have it, yes, you do indeed need to submit the new certificate everywhere
