[SOLVED] Provide an existing winpe.wim file
Nats
Registration: May 23, 2023 - 08:33
June 1, 2023 - 3:07 PM
I want to download WinPE, but as soon as I try to install it I get this error:
However, I do have the package mentioned installed, so I don't understand.
WAPT Enterprise 2.3
Administration Machine: Windows 10 Pro
June 1, 2023 - 3:35 PM
Is the file
"C:\Program Files (x86)\Windows Kits\10\Assessment and Deployment Kit\Windows Preinstallation Environment\amd64\en-us\winpe.wim"
present on the machine?
It is placed by tis-wads-requirement-minimal.
Nats
June 1, 2023 - 4:47 PM
sfonteneau wrote: June 1, 2023 - 3:35 PM The file:
Is it present on the machine?
No, the file is not present; even the Windows Kits folder doesn't exist at all
June 1, 2023 - 4:52 PM
Can you type the command:
wapt-get list wads
in a command prompt to check if the package is installed
Nats
June 1, 2023 - 4:58 PM
sfonteneau wrote: June 1, 2023 - 4:52 PM Can you type the command:
wapt-get list wads
Actually, for some reason, I can't deploy the agent on my administration machine using WAPT; it's the only machine I'm missing. I've even tried deploying it, and it doesn't work, so I can't install the package; I can only download it from that machine...
June 1, 2023 - 5:15 PM
Did you install the agent on your own machine?
Nats
June 2, 2023 - 9:40 AM
sfonteneau wrote: June 1, 2023 - 5:15 PM Did you install the agent on your own machine?
Great, I successfully installed the agent on my configuration machine, but now I have another problem. I'd like to know how to boot with the WAPT OS deployment, because I followed the live stream where you showed how to deploy the OS, but I get this error when I launch my virtual machine:
Could you please tell me how to do this? Thank you
June 5, 2023 - 10:15
Did you follow this guide? The video is good, but the guide is better...
https://www.wapt.fr/fr/doc/wapt-wads.ht ... p-for-wads
June 13, 2023 - 2:19 PM
Hello Nats,
since I haven't received a response, I'm marking this topic as resolved.
Regards,
