[SOLVED] "Files corrupted" problem during package installation
brice73
Registration: February 13, 2023 - 8:05 AM
June 5, 2023 - 1:51 PM
I recently created a package for installing the Ardublock 2.0 software. I verified its successful installation/uninstallation with PyScriptor. After importing it into the server (package creation), when I try to install it from the console, I get the following error message:
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1282, in _run
Exception: Erreur lors de l'installation de ['col73-ardublock-2.0(=2.0-1)']: erreurs dans les paquets [[PackageRequest(package='col73-ardublock-2.0',version=(Version('2.0.0.0'), 1),architectures=['x64'],locales=['fr'],maturities=['PROD', 'DEV'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19044.2965'),max_os_version=Version('10.0.19044.2965')), PackageEntry('col73-ardublock-2.0','2.0-1' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5193, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4167, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3956, in install_wapt\n    packagetempdir = entry.unzip_package(cabundle=self.cabundle, target_dir = tempfile.mkdtemp(prefix=\'wapt\',dir=self.wapt_temp_dir))\n  File "C:\\Program Files (x86)\\wapt\\waptpackage.py", line 2623, in unzip_package\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\waptpackage.py", line 2615, in unzip_package\n    verified_by = self.check_package_signature(cabundle,ignore_missing_files=ignore_missing_files)\n  File "C:\\Program Files (x86)\\wapt\\waptpackage.py", line 2573, in check_package_signature\n    raise EWaptCorruptedFiles(\'Error in package %s in %s, [b][size=150]files corrupted, SHA not matching[/size] [/b]for %s\' % (self.asrequirement(), self.sourcespath, errors,))\nwaptpackage.EWaptCorruptedFiles: Error in package col73-ardublock-2.0(=2.0-1) in C:\\Windows\\TEMP\\wapto3v5s3pi, files corrupted, SHA not matching for [\'ArduBlock 2.0/app/compilation/python/Lib/site-packages/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_internal/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/cachecontrol/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/chardet/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/distlib/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/html5lib/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/urllib3/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/urllib3/contrib/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pip/_vendor/urllib3/packages/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/pyflakes/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/serial/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/setuptools/__pycache__\', \'ArduBlock 2.0/app/compilation/python/Lib/site-packages/setuptools/_vendor/__pycache__\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/.gitignore\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/.travis.yml\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/print/.due.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/print/.esp32.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/print/.m4.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/print/.zero.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/res/.due.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/res/.esp32.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/res/.m4.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-Fingerprint-Sensor-Library-master/examples/res/.zero.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-GFX-Library-master/.gitignore\', \'ArduBlock 2.0/install/libraries/Adafruit-GFX-Library-master/.travis.yml\', \'ArduBlock 2.0/install/libraries/Adafruit-ST7735-Library-master/.gitignore\', \'ArduBlock 2.0/install/libraries/Adafruit-ST7735-Library-master/.travis.yml\', \'ArduBlock 2.0/install/libraries/Adafruit-ST7735-Library-master/examples/miniTFTWing/basic/.mega2560.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit-ST7735-Library-master/examples/miniTFTWing/graphicstest/.mega2560.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/RGBWstrandtest/.esp8266.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/RGBWstrandtest/.trinket.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/StrandtestBLE/.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/buttoncycler/.esp8266.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/simple/.esp8266.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/simple_new_operator/.esp8266.test.skip\', \'ArduBlock 2.0/install/libraries/Adafruit_NeoPixel-master/examples/strandtest/.esp8266.test.skip\', \'ArduBlock 2.0/install/libraries/HX711/.gitignore\', \'ArduBlock 2.0/install/libraries/IRremote/.gitignore\', \'ArduBlock 2.0/install/libraries/IRremote/.travis.yml\', \'ArduBlock 2.0/install/libraries/TEA5767-master/.gitignore\', \'ArduBlock 2.0/install/libraries/iarduino_MultiServo-1.1.3/.gitattributes\', \'ArduBlock 2.0/install/libraries/iarduino_Pressure_BMP-2.0.2/.gitattributes\']\n']]
I recently encountered this error problemfiles corrupted, SHA not matching"during installation from the console, especially when the installation requires copying locally, from the package, of files with names containing accented characters (é, è, à ...) or empty folders.
I saw that a topic had been opened about this: viewtopic.php?p=11573&hilit=corrupted+files#p11573
It seems the problem hasn't been completely resolved? Is there a way to deploy the package in question while working around the issue until it's fixed? Will the upcoming version 2.4 fix this problem?
WAPT Enterprise 2.6.1.17765
WAPT server under Debian 13
Administration/package creation under Windows 11/10
June 5, 2023 - 2:10 PM
I just tested version 2.4 using the package build from the console. It works well, however, the pyc files are deleted from the folders during the build process. I'll look into how to prevent this deletion.
brice73
June 5, 2023 - 5:10 PM
Hello Simon,
Thank you for your reply. We will soon be upgrading to version 2.4. I will try again once the version change has been completed.
Best regards,
Brice
June 13, 2023 - 2:16 PM
Hi Brice,
version 2.4 with the fix is ​​out, I'm marking this topic as resolved.
Regards,
