- WAPT Enterprise 2.4
- agent version: 2.2.3
- server OS (Linux)
- administration OS (Windows)
Hello, I've noticed that the username information for some of my Linux workstations is returning "gdm" instead of the session username. Do I need to create a package to return this information, or should I review the configuration of the agents deployed on the Linux machines (they are running Ubuntu 22.04)?
Thank you, Thomas.
Username Linux WAPT
- WAPT Expert
Good morning
On the machines that have the problem, can you run these commands to see the result?
loginctl list-sessionsCode: Select all
waptpython
import psutils
print(psutil.users())
- WAPT Expert
Hi Thomas,
when you mention the username, are you referring to the last_logged_on_user, the logged_on_user, or another inventory attribute?
Are users logged in when this behavior occurs?
Actually, after reviewing the code, I think this function can be significantly improved. I'll discuss it with my colleagues.
Best regards,
Best regards,
The problem seems random; it reverts to the correct username instead of "gdm," which is quite strange. And the user, at the moment I see "gdm," is indeed logged in with the username I'm supposed to see.
@dcardon > I was referring to "Logged in users" in my request.
I also tried creating a package using the commands recommended above, but nothing is flagged in the audit log when I put the package on the machine... (I'd like to correct "import psutils" > "import psutil")
Regards, Thomas.
Regards, Thomas.
