[SOLVED] Error downloading WSUSSCAN
elchapulin
Registration: June 9, 2023 - 2:47 PM
June 9, 2023 - 2:50 PM
I'm testing WAPT Enterprise for my association, and so far everything is working.
The agent is created and deployed on a VM in a "LAB" OU.
I can deploy packages, however, I'm getting the message "ERROR DOWNLOADING WSUSSCAN" in the WUA column, which I can't resolve.
Can you help me, please?
El Chapulin.
June 9, 2023 - 3:32 PM
in the Windows Update tab of the console, click on "Download the WSUSScan cab from Microsoft" (this is done automatically every night).
Then click on "View download history." A download task should have downloaded the wsusscn2.cab file.
Check for any errors.
You can now run another scan on the machines.
elchapulin
June 9, 2023 - 6:33 PM
thank you for your feedback.
It seems it's not working, see attached image.
Thank you for your help. :)
June 12, 2023 - 09:38
In the message column you can read the error message.
Often this happens when you have a proxy and it has not been declared in the wapt configuration.
https://www.wapt.fr/fr/doc/wapt-securit ... server-ini
Add http_proxy to the options section of the /opt/wapt/conf/waptserver.ini file
[section]
http_proxy=http://srvproxy.mydomain.lan:8080
elchapulin
June 12, 2023 - 10:08 PM
Sir,
here is the error message:
Exception: wget: not enough free space on target drive to get http://download.windowsupdate.com/micro ... usscn2.cab MB. Total size: 807 MB. Free space: 520 MB.
Thank you!
June 12, 2023 - 11:53 PM
elchapulin wrote: ↑June 12, 2023 - 10:08 p.m. Exception: wget: not enough free space on target drive to get http://download.windowsupdate.com/micro ... usscn2.cab MB. Total size: 807 MB. Free space: 520 MB
Great, you just need to increase your server's disk space and you're good to go ;)
elchapulin
June 13, 2023 - 09:55
I have 78% free disk space on my Debian system....
June 13, 2023 - 10:08
df -Ph /var/www/waptwua/
What does this yield?
elchapulin
June 13, 2023 - 12:12
/dev/mapper/collectifalliance--wapt--vg-var 1.6G 1.1G 481M 69% /var
June 13, 2023 - 12:27
Hi Anthony,
the last column shows the used space, not the available space. ;)
And 31% of 1.6GB isn't enough for a wsuscn2.cab file... :-)
Regards,
