WAPT Linux console column display
Share your experience and thoughts about WAPT here / Come here and talk about your experience with Wapt, your opinion and your wishes
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
thomas789
Registration: May 31, 2021 - 3:44 p.m.
June 19, 2023 - 4:23 PM
I'm using Ubuntu 22.04,
WAPT console 2.2.3.12,
and WAPT server 2.4.0.
I'm reporting a bug with the WAPT Linux console. When using the system's built-in dark mode in Ubuntu 22.04 and modifying the column spacing (any tab, Inventory, Requested Items, etc.), the text becomes blurry and unreadable (see attached image). This only happens in dark mode.
Thank you in advance,
Best regards.
Screenshot from 2023-06-19 16-17-46.png (33.81 KB) Viewed 52638 times
bkolovljanovic
Registration: Apr 20, 2022 - 2:26 p.m.
June 19, 2023 - 6:03 PM
I see that the versions between the server and the console don't match, according to the information you provided.
Have you also tried with a console running version 2.4? (unless it's a typo)
thomas789
June 20, 2023 - 4:56 PM
I made a mistake in my information; I am indeed using the WAPT 2.4.0.14058 console.
Thank you, best regards.
June 21, 2023 - 09:30
Hi Thomas,
we didn't see this bug when we made the bug fixes for console support in dark mode under Linux.
Could you tell me the exact name of the theme used and which desktop environment you're using? Has the theme been modified (typography, font size, etc.)? We'll try to reproduce the problem internally.
Regards,
thomas789
June 21, 2023 - 11:28
I don't use a custom theme; it's the one that comes pre-installed in Ubuntu 22.04 GNOME (Settings > Appearance > Dark).
Thomas.
