copy a file
meree
Registration: Apr 19, 2023 - 06:15
June 19, 2023 - 1:56 PM
I would like some help installing a package. I have a folder containing subfolders, and I'd like to know how to deploy this folder to a computer (copy and paste) while still maintaining the ability to synchronize its contents (it contains an .exe file (start) that doesn't need to be installed, just copied).
Should I create a package for copying and pasting? If so, what should I write in the script?
Server: WAPT Enterprise 2.4.0.14031 on Debian.
Consoles: Windows 11.
Network: Windows
Screenshot .png (30.53 KB) Viewed 8687 times
June 20, 2023 - 3:22 PM
you can look at the packages on the store; there's quite a bit of code to get inspiration from. In this case, the `copytree2` command should do the trick. [1]
Regards,
[1] https://www.wapt.fr/fr/doc/wapt-create- ... -directory
meree
June 26, 2023 - 07:39
sorry for the late reply.
I've already tried using CopyTree2, but the problem is that when I try to copy folders from the local computer where the WAPT console is installed to another computer on the network, it shows me an error message: "The filename, directory, or volume label syntax is incorrect."
Is there also a way to create a shortcut in the Startup folder so the program runs when the computer is turned on? I've searched everywhere but haven't found anything, and I've tried several methods, but it still doesn't work.
Thank you in advance for any advice you can give me.
Screenshot 2023-06-20 093514.png (76.96 KB) Viewed 8631 times
Gaelds
Registration: Nov 22, 2015 - 08:37
June 26, 2023 - 08:20
The folder to be copied must be in the package. Here is an example for portable software:
app_dir = makepath(programfiles, 'Inventoria')
src_dir = r'./Inventoria'
    if not isdir(app_dir):
        mkdirs(app_dir)
    copytree2(src_dir,app_dir,onreplace = default_overwrite)
meree
June 26, 2023 - 09:23
thank you for your reply.
The problem is that I'm creating an empty package, and there's no way to add the folder containing the files to the package. That's why I'm creating an empty package and using PyScripter to code and deploy it from my computer, but when I use CopyTree, it doesn't work, as I've already shown.
Another question, please: is there a way to create a shortcut in the startup folder?
Thank you in advance.
June 26, 2023 - 10:05
meree wrote: ↑June 26, 2023 - 09:23 The problem is that I create an empty package and there is no way to add the folder with the files to the package. That's why I create an empty package and use Pyscripter to code the package and deploy the package from my computer, but when I use copytree, it doesn't work as I've already shown.
It doesn't work because the software source code isn't in the package. Please consult the documentation or other packages in the store. Network shares should not be referenced in setup.py.
One more question please, are there ways to create a shortcut in the startup folder?
Please do not ask multiple questions in the same topic, see forum rules.
