[SOLVED] Modifying the uninstallation key of a WAPT package
erems
Registration: Apr 25, 2023 - 3:52 p.m.
July 5, 2023 - 5:12 PM
I'm using the package creation wizard to create a package from an MSI file, but the detected uninstallation key is incorrect.
The field is grayed out. How can I change the key?
Thank you for your help.
Regards.
July 7, 2023 - 7:49 AM
Click on "Edit manually" then in the generated Python code, in the line install_msi_id_needed(....)
Add a "key" parameter with the correct key
    # Declaring local variables
    # Installing the software
    print("Installing: ZimbraConnectorOLK_9.0.0.1930_x64.msi")
    install_msi_if_needed('ZimbraConnectorOLK_9.0.0.1930_x64.msi', key='xwxwxwxcwxcwxcxwc')
erems
July 10, 2023 - 10:31
it works.
Thank you.
