[SOLVED] Exclude a package from the installation when machines are shut down
regis.lemonnier
Registration: Oct 15, 2022 - 4:41 p.m.
July 6, 2023 - 1:49 PM
is it possible to prevent a package from installing when the machine is shut down?
WAPT version installed: 2.2.1.11957
Server OS: Red Hat Enterprise Linux 8.6
Administration machine OS: Windows 10
July 7, 2023 - 8:44 AM
You can add a parameter "'upgrade_priorities'" in wapt-get.ini to only consider packages that are in the listed priorities during the upgrade.
To exclude, you must therefore assign a priority to the package to be excluded that is different from what will be specified in this parameter
For example,
wapt-get.ini:
[global]
upgrade_priorities=critical,optional
and put
priority=skip
in the package control file
regis.lemonnier
July 7, 2023 - 9:58 AM
OK thanks.
On the online documentation (https://www.wapt.fr/fr/doc-2.2/wapt-pac ... cture.htmlIt is indicated that this parameter is not currently supported. Will it still work with WAPT 2.2.1.11957?
The possible priorities are as follows:
Critical, High, Medium, Low, Optional
htouvet wrote: July 7, 2023 - 8:44 AM You can add a parameter "'upgrade_priorities'" in wapt-get.ini to only consider packages that are in the listed priorities during the upgrade.
For example,
wapt-get.ini:
[global]
and put
priority=skip
regis.lemonnier
July 10, 2023 - 5:28 PM
Thank you, it works.
regis.lemonnier wrote: July 7, 2023 - 9:58 AM OK thanks.
For example,
wapt-get.ini:
[global]
and put
priority=skip
July 21, 2023 - 2:19 PM
Hi Régis,
thanks for the feedback :-) . I'm marking the topic as [RESOLVED].
