is it possible to format a dialog box using the command: waptguihelper.message_dialog or another command?
If so, where can I find the available options?
[SOLVED] Customizing a waptguihelper.message_dialog dialog box
regis.lemonnier
- Registration: Oct 15, 2022 - 4:41 p.m.
WAPT version installed: 2.2.1.11957
Server OS: Red Hat Enterprise Linux 8.6
Administration machine OS: Windows 10
waptguihelper doesn't offer any real customization options...
One question at a time.
Apart from waptguihelper.grid_dialog(..) which allows input in a grid
Alternatively, you can use waptmessage with an HTML form
Example:
setup.py
Parameters:
- Title: the title for the dialog
- Data: a list or JSON string
Optional:
- ResultType: GRT_ALL or GRT_SELECTED - default is GRT_ALL
- MetaData: it can be used to change columns data type
- it must be a JSON
- all types: String, Date, Time, DateTime, Integer, Float, Boolean, Memo
- example: {"columns":[{"propertyname":"id","datatype":"Integer"}]}
- Text: the label above search box - default is "Search"
- StayOnTop: indicates if the form will always stay on top - default is FalseExample:
setup.py
import base64
import json
form = """\
<html encoding="utf8">
<form method="STDOUT">
<h2>Formulaire</h2>
Votre machine :
<input type="text" name="machine" value="%(machine)s"><br>
Votre nom:
<input type="text" name="nom" value="%(nom)s"><br>
Votre prénom:
<input type="text" name="prenom" value="%(prenom)s"><br>
<label for="pet-select">Choose a pet:</label>
<select name="pets" id="pet-select">
<option value="">--Please choose an option--</option>
<option value="dog">Dog</option>
<option value="cat">Cat</option>
<option value="hamster">Hamster</option>
<option value="parrot">Parrot</option>
<option value="spider">Spider</option>
<option value="goldfish">Goldfish</option>
</select>
<input type="submit" value="Valider">
</form>
</html>
pass
def update_package():
nom = ''
prenom = ''
machine = get_computername()
pets=''
s = base64.b64encode((form % locals()).encode('utf8'))
result = run(['waptmessage','-c','-b',s])
if result:
data = json.loads(result)
nom = data['result']['nom']
prenom = data['result']['prenom']
machine = data['result']['machine']
pets = data['result']['pets']
print("""\
Nom: %s
Prénom: %s
Machine: %s
Animal: %s
""" % (nom,prenom,machine,pets))
regis.lemonnier
Using waptmessage with HTML meets my display needs, but when I use the code portion provided as an example, the "if result" returns 'False' even though the form fields are completed and validated (buttons "Validate" + Ok).
Any idea what caused the failure?
htouvet wrote: ↑July 6, 2023 - 4:27 PM waptguihelper doesn't offer any real customization options...
Apart from waptguihelper.grid_dialog(..) which allows input in a gridAlternatively, you can use waptmessage with an HTML formCode: Select all
Parameters: - Title: the title for the dialog - Data: a list or JSON string Optional: - ResultType: GRT_ALL or GRT_SELECTED - default is GRT_ALL - MetaData: it can be used to change columns data type - it must be a JSON - all types: String, Date, Time, DateTime, Integer, Float, Boolean, Memo - example: {"columns":[{"propertyname":"id","datatype":"Integer"}]} - Text: the label above search box - default is "Search" - StayOnTop: indicates if the form will always stay on top - default is False
Example:
setup.py
# -*- coding: utf-8 -*- from setuphelpers import * import base64 import json form = """\ <html encoding="utf8"> <form method="STDOUT"> <h2>Formulaire</h2> Votre machine : <input type="text" name="machine" value="%(machine)s"><br> Votre nom: <input type="text" name="nom" value="%(nom)s"><br> Votre prénom: <input type="text" name="prenom" value="%(prenom)s"><br> <label for="pet-select">Choose a pet:</label> <select name="pets" id="pet-select"> <option value="">--Please choose an option--</option> <option value="dog">Dog</option> <option value="cat">Cat</option> <option value="hamster">Hamster</option> <option value="parrot">Parrot</option> <option value="spider">Spider</option> <option value="goldfish">Goldfish</option> </select> <input type="submit" value="Valider"> </form> </html> """ def install(): pass def update_package(): nom = '' prenom = '' machine = get_computername() pets='' s = base64.b64encode((form % locals()).encode('utf8')) result = run(['waptmessage','-c','-b',s]) if result: data = json.loads(result) nom = data['result']['nom'] prenom = data['result']['prenom'] machine = data['result']['machine'] pets = data['result']['pets'] print("""\ Nom: %s Prénom: %s Machine: %s Animal: %s """ % (nom,prenom,machine,pets))
This might be due to the version difference. I tested the code snippet with my development version of Wapt.
You're apparently using version 2.2.
You can try running it manually in a command prompt to see the output (or lack thereof in your case).
This works with ensure_unicode
s = ensure_unicode(base64.b64encode((form % locals()).encode("utf8")))
{"method":"STDOUT","action":"","target":"","enctype":"","result":{"machine":"jpe-clt-win11","nom":"jghjgj","prenom":"","pets":"--Please choose an option--"}}
