Hello everyone.
I'm deploying the agent via GPO with WAPTdeploy and I'm in configuration #3 (requires WAPT authentication for machine registration. The WAPT server will request the SuperAdmin password for each new registration).
How can I integrate the password into my GPO?
In my GPO, I have the WAPTdeploy executable selected with the following arguments: --hash=hashhashhashhashhash --minversion=2.4.0.14031 --wait=15 --waptsetupurl=https://wapt.myserver.net/api/v3/get_ ... tagent.exe.
Thanks everyone.
[RESOLVED] Deployment via GPO with password
Since it's been a while since you asked the question, I don't know if you've found a solution.
If that's not the case, here's how I do it:
with the following parameters:
where LOGIN and PASSWORD are the credentials of the previously created user.
A machine restart is usually required after WAPT installation for it to be registered on the server, but this method works well.
- I created a WAPT user via the console, which only has the rights to register machines on the server (to improve security, but it also works with an admin user)
- In the GPO, I added waptdeploy.exe (with arguments) as a startup script
- I then added a second startup script:
wapt-getCode: Select all
register --wapt-server-user=LOGIN --wapt-server-passwd=PASSWORDA machine restart is usually required after WAPT installation for it to be registered on the server, but this method works well.
Server: WAPT Enterprise 2.4.0.14143 on Debian
Console: Windows 10
Infrastructure: Windows
Console: Windows 10
- WAPT Expert
Thanks Guillaume for this detailed answer
. I'm marking the topic as resolved.
