[RESOLVED] rights under the www folder
jptw
Registration: July 8, 2020 - 11:08 AM
August 3, 2023 - 4:53 PM
I'm having a small problem:
during the last WUA update, one of my colleagues propagated the permissions of the "/var/www" folder instead of those of "/var/www/waptwua",
which prevents the upload of any packages or anything else.
From memory, the permissions of the waptwua folder are "wapt:www-data", but I don't remember the exact permissions of the other folders.
Is there a simple way to restore the original permissions under /var/www for all the wapt folders?
Server version 2.3 Enterprise,
Debian 10.
Thank you.
kguerineau
Registration: March 6, 2018 - 4:28 PM
August 7, 2023 - 10:19
The permissions on the "waptwua" folder are wapt:www-data 750.
Regards
jptw
August 7, 2023 - 2:40 PM
Thank you
, and it's the same for the other folders,
because as I said, it's all the folders under /var/www that have been modified,
so wapt, wads, wapt-host etc....
kguerineau
August 8, 2023 - 09:35
Here are the rights:
-rw-r--r-- 1 wapt www-data     licences.json
-rw-r----- 1 wapt www-data     rules.json
drwxr-x--- 2 wapt www-data     ssl/
-rw-r----- 1 wapt www-data     sync.json
drwxr-xr-x 6 wapt www-data     wads/
drwxr-x--- 8 wapt www-data     wapt/
drwxr-x--- 2 wapt www-data     wapt-diff-repos/
drwxr-x--- 2 wapt www-data     wapt-host/
drwxr-x--- 3 wapt www-data     waptwua/
Good day
jptw
August 8, 2023 - 2:17 PM
Thanks so much!
