Deploy GLPI Agent
SebR
Registration: June 10, 2022 - 3:14 PM
August 4, 2023 - 09:17
I'm trying to deploy the GLPI agent on our network. We tried using a GPO, but it didn't work.
I tried creating a package via WAPT, but we can't seem to insert the correct arguments (`/qn /i RUNNOW=1 SERVER="htt*://server/front/inventory.php")` in the Py file.
We saw that there's a GLPI package in WAPT, but we don't see how to add the arguments (server name and installation type).
Do you have any ideas, or does anyone have an example of how to build the package?
Thanks in advance for your help.
Sebastien
jorico
Registration: August 11, 2022 - 4:42 PM
August 4, 2023 - 1:56 PM
Hello Seb,
I installed the GLPI agent this way on my network, but I did not use the package from the repository, nor did I manage to integrate the arguments with the package from the store.
I added audit functions to check the status of the service.
r"""
uninstallkey = ['{E1BE6C18-6BF4-1014-844A-F1F114E3EA24}']
    # Declaring local variables
    # Installing the software
    print("Installing: GLPI-Agent-1.4-x64.msi")
    run(r'MsiExec.exe /i GLPI-Agent-1.4-x64.msi /quiet SERVER=https://xxxxxxxxxxx  ADD_FIREWALL_EXCEPTION=1 SCAN_PROFILES=1 RUNNOW=1')
    print("Installation de GLPI-Agent-1.4 terminée")
def audit():
   if service_is_running('glpi-agent'):
    print("Le service GLPI Agent est démarré")
    return "OK"
    print("Le service GLPI Agent n'est pas démarré !")
    return "WARNING"
WAPT Enterprise 2.5.5.15697
Server = Debian 11 Bullseye
Console = Windows Server 2019
Johan
blemoigne
Registration: July 17, 2020 - 11:29
August 16, 2023 - 10:42
It would be in this form:
    install_msi_if_needed(
        glob.glob("*.msi")[0], properties ='RUNNOW=1 SERVER="htt*://serveur/front/inventory.php"'    )
Bertrand
SeiyaGame
Registration: May 25, 2023 - 3:19 p.m.
August 22, 2023 - 3:51 PM
I would like to propose my solution which, while incorporating your ideas, also includes some improvements :D
import glob
# https://glpi-agent.readthedocs.io/en/latest/installation/windows-command-line.html#command-line-parameters
properties = {
    "RUNNOW": 1,
    "ADDLOCAL": "feat_NETINV,feat_DEPLOY,feat_COLLECT", # ALL Or feat_AGENT,feat_NETINV,feat_DEPLOY,feat_COLLECT,feat_WOL
    "ADD_FIREWALL_EXCEPTION": 1,
    "AGENTMONITOR": 1,
    "SERVER": "http://URL_SERVER/marketplace/glpiinventory/",
    exe_file = glob.glob("*.msi")[0]
    print(f"Installing: {exe_file}")
    install_msi_if_needed(exe_file, properties=properties)
def audit():
    if service_installed("glpi-agent") and service_is_running("glpi-agent"):
        print("Service installed and started!")
        return "OK"
        print("Service is not installed and started !")
        return "ERROR"
