I'm working on creating a package for installing Citadel Team. The installer is in .exe format.
However, I'm having a problem: I can't specify an uninstallation key in the "key=''" field because I haven't been able to find a corresponding key.
Even using the `wapt-get list-registry` command doesn't work.
This is because the program installs in the user's profile.
Do you have a solution to suggest to work around this problem?
WAPT version: 2.3
Server OS: Windows Server 2019
Administration machine OS: Windows 10
Missing uninstall key with Citadel Team
Ideally, you should find the ALLUSERS flag for the application, or ask the developer for it. If necessary, you can try installing it as a user.
https://wapt.tranquil.it/store/fr/tis-discord could be a good example.
Regards,
Jimmy
Regards,
Jimmy
