I get an error message when I try to install a package generated by the WAPT console.
The product is W11Classicmenu, and to install it, you need to copy the directory. So I used the "Windows portable application" option
Unfortunately, here is the error message I get when I try to install it:
File "C:\Program Files (x86)\wapt\common.py", line 4009, in install_wapt
setup = import_setup(setup_filename)
File "C:\Program Files (x86)\wapt\waptutils.py", line 1525, in import_setup
File "imp.py", line 171, in load_source
File "<frozen importlib._bootstrap>", line 702, in _load
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 839, in exec_module
File "<frozen importlib._bootstrap_external>", line 976, in get_code
File "<frozen importlib._bootstrap_external>", line 906, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\WINDOWS\TEMP\wapt1fubbh_4\setup.py", line 26
print("Copying directory: %%s to: %%s" %% (dir_name, app_dir))
SyntaxError: invalid syntax
SyntaxError: invalid syntax (setup.py, line 26)The setup.py file seems correct to me:
r"""
dir_name = 'W11ClassicMenu'
app_name = 'W11ClassicMenu'
app_exe = 'W11ClassicMenu.exe'
app_dir = makepath(programfiles32, dir_name)
app_path = makepath(app_dir, app_exe)
# Initializing variables
# Installing software
print("Installing: mgp-W11ClassicMenu")
killalltasks(control.get_impacted_process_list())
mkdirs(app_dir)
if isdir(app_dir):
remove_tree(app_dir)
mkdirs(app_dir)
copytree2(dir_name, app_dir)
# Creating shortcuts
create_desktop_shortcut(app_name, app_path)
create_programs_menu_shortcut(app_name, app_path)
# Uninstalling software
if isdir(app_dir):
# Removing shortcuts
remove_desktop_shortcut(app_name)
remove_programs_menu_shortcut(app_name)
def audit():
# Declaring local variables
package_version = '1.2.0.0'
# Getting installed software version
if isfile(app_path):
installed_version = get_version_from_binary(app_path)
else :
installed_version = None
# Auditing software
print("Auditing: mgp-W11ClassicMenu")
if installed_version is None or installed_version < package_version:
print("%%s version is incorrect (%%s)" %% (app_name, installed_version))
return "ERROR"
print("%%s is installed in correct version (%%s)" %% (app_name, installed_version))
return "OK"If you have any idea what the problem might be...
Thanks in advance
Eric
