WAPTConsole Enterprise version 2.2.1.11957
Console: Win19 server
SRV: Debian 11
Hello, following the upgrade from version 2.2 to 2.4, I wanted to try enabling authentication for OS deployment to test, but I'm encountering a problem: an "invalid credential" error message even though I'm entering the correct credentials.
I used the console's admin account login.
Thank you in advance.
Invalid credential OS deployment
Do you have the following two lines in /opt/wapt/conf/waptserver.ini?
Alternatively, we can test with another user who has the correct ACL (admin or wads_admin or wads_host_deploy).
login_on_wads = True
wads_enable = True
