[SOLVED] How to uninstall non-Wapt software?
CasseThor
Registration: December 1, 2017 - 9:25 PM
December 1, 2017 - 9:42 PM
Good evening everyone,
your software is really great, and while browsing it (wapt server on Windows),
I saw in the console that it lists all the installed software along with commands to uninstall them.
Is it possible to do this from the console on Windows?
Perhaps in a future server update?
Have a good evening, given the time. :mrgreen:
Regards.
PS: Your software is great, I'm going to convert all my MSI packages. :D
December 2, 2017 - 12:31
Good morning
In the console, you can only launch uninstallations of wapt packages.
To uninstall software, you can create a package, for example: tis-remove-bloatware
The code snippet that allows you to do this is available in the documentation here:
https://www.wapt.fr/fr/doc/CreationPaqu ... -logiciels
So for you:
for soft in installed_softwares('cyberlink'):
will uninstall all software that has the word cyberlink in its uninstallkey information
It would indeed be possible to perform an action directly from the console, but this is not planned at the moment.
CasseThor
December 2, 2017 - 5:09 PM
baal
Registration: Sep 06, 2023 - 3:34 p.m.
September 6, 2023 - 3:38 PM
Can we add parameters
to the uninstallation command:
run(WAPT.uninstall_cmd(soft['key'])) to perform a silent uninstallation?
September 7, 2023 - 10:10
Hello Baal,
it's not recommended to "resurrect" old posts (see necroposting on Wikipedia). Could you please start a new thread?
I'm closing this one.
Regards,
