[SOLVED] pb wapt version check
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
September 6, 2023 - 10:48
Hello everyone,
Since the update to 2.4.0.14143, the wapt console keeps telling me that the agent is not up to date even though it is because I have already done it 2 times.
Screenshot 2023-09-06 104454.png (10.84 KB) Viewed 13339 times
Screenshot 2023-09-06 104530.png (3 KB) Viewed 13339 times
However, the package itself shows that it is the correct version:
Screenshot 2023-09-06 104601.png (13.21 KB) Viewed 13339 times
Any ideas?
Thanks in advance !
Guillaume
guigeek
September 8, 2023 - 8:36 AM
Is no one else having this problem?
September 8, 2023 - 9:25 AM
Hello Guillaume,
server OS version, etc. (see forum rules).
If it's Linux (this isn't mentioned, see forum rules...), could you please check if /var/www/wapt/waptagent.exe is a symbolic link or not?
Regards,
blemoigne
Registration: July 17, 2020 - 11:29
September 8, 2023 - 9:26 AM
I think it's because you first created it in DEV and then changed the maturity. In that case, the agent isn't actually generated.
Bertrand
guigeek
September 8, 2023 - 12:53
Ah yes, that's exactly it!
THANKS !
blemoigne wrote: ↑September 8, 2023 - 9:26 AM Hello,
Bertrand
guigeek
September 8, 2023 - 4:28 PM
It works perfectly!
