Uninstalling "non-WAPT" software
Answer
sebastien4444
Registration: Sep 14, 2023 - 08:53
September 15, 2023 - 6:20 PM
is it possible to uninstall software from a PC that wasn't installed via WAPT? (Since already installed software isn't listed in the machine's packages).
I managed to do it by creating an uninstallation package (overriding the `install()` function in `setup.py` with a `run()` call from the uninstallation executable), but I'm wondering if there's a cleaner way, one that WAPT supports.
Thanks in advance for your help.
September 18, 2023 - 12:28
Hi Sébastien,
the method you used is correct. You can then install multiple uninstallers within the same package (internally, we call this an anti-crapware package :-) ). Regarding the uninstallation keys, you can view them in the WAPT console under the "Software Inventory" tab when you select a machine. The uninstaller needs to be silent, which unfortunately isn't always the case...
The plan for the future (when the development team has some time :-) ) is to have a wizard in the WAPT console to differentiate between software installed by WAPT and software installed outside of WAPT, to help with the setup of this anti-crapware package.
Best regards,
Answer
