Update 2.4.0.14143 WAPT Server: Local WAPT configuration --> parameter not retrieved
Answer
Stephane
Registration: Sep 25, 2023 - 11:55
September 25, 2023 - 2:51 PM
I updated the WAPT/Windows server version to 2.4.0.14143, and the installer isn't retrieving the default settings in the local WAPT configuration.
I had to enter them manually.
Is this normal? Is it a bug?
Thank you in advance for your reply
. Best regards,
Answer
