I have a network of computers where IE8 32-bit (default) and IE8 64-bit are installed.
I want to create a 32-bit IE11 package initially, but I'm encountering some problems. I downloaded the executable from the official website: http://windows.microsoft.com/en-us/inte ... -languages.
When I try to run the command "wapt-get build-upload", I get the following error in the terminal: FATAL ERROR: ValueError: 11.00.9600.16428
Just a quick note: I tried using the ready-made package available on the Store, but I also get an error message and the task stops.
Regards,
IE Package 11
benlukas62
- Registration: May 12, 2016 - 5:36 p.m.
Thank you for your reply.
Indeed, that was the problem. However, 11.9600-0 didn't work either. I ended up downloading the control file from the pre-made package on the WAPT Store.
Regards,
Regards,
