On a fresh installation, I'm trying to register clients via Kerberos (if I understand correctly, this feature exists) but the WAPT Register command returns warnings and asks me for a username:
C:\Windows\System32>wapt-get register
2023-10-06 17:39:33,457 WARNING Host client certificate C:\Program Files (x86)\wapt\private\4C4C4544-0044-4810-8038-C2C04F4D3533.crt is self signed or not with client_auth capability, not using it for auth on global
Registering host against server: https://si-wapt-01.ad.interstis.fr
2023-10-06 17:39:34,153 WARNING Host client certificate C:\Program Files (x86)\wapt\private\4C4C4544-0044-4810-8038-C2C04F4D3533.crt is self signed or not with client_auth capability, not using it for auth on wapt
2023-10-06 17:39:34,155 WARNING Host client certificate C:\Program Files (x86)\wapt\private\4C4C4544-0044-4810-8038-C2C04F4D3533.crt is self signed or not with client_auth capability, not using it for auth on wapt-host
Please get login for add_host:I tried a
wapt-get enable-check-certificateI tried to pin the certificate as suggested in the documentation, same result.
I tried to recreate an initial configuration --> but what's the point of that? And what do I do with the JSON?
I tried to rebuild or recompile a wapt agent... it runs, it compiles, it downloads somewhere, then... nothing (well, what should I do after that?)
When I try to access my Wapt server http://mon-wapt.mon-domaine.fr/waptChrome and Edge refuse to connect (self-signed certificate). Firefox accepts a workaround.
How can I register my WAPT clients, please?
Thanks in advance.
