I'm using a Debian 12 Linux VM with WAPT 2.4 installed. I can use the WAPT console on Windows 10, but not on Windows Server 2019. Is this a known issue?
Joel Marchand
Console on Windows Server 2019
- WAPT Expert
no known problems.
Could you provide more information about what isn't working?
no known problems.
During the installation/registration of waptsetup, I see the following in the WAPT server logs
: root@wapt:/var/log# cat waptserver.log
Oct 8 13:37:01 wapt waptserver[812]: 2023-10-08 13:37:01,428 [waptserver ] WARNING Unauthenticated registration for fsecure2
root@wapt:/var/log#
Then, when I launch the console from W2019, it tells me:
The following servers are not responding: https://wapt.ijm.fr
I have no trace of the firewall between the console and the server.
A tcpdump on the server clearly shows that it receives the console connection and responds:
13:47:26.714529 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [P.], seq 1:276, ack 1, win 32768, length 275
13:47:26.714583 IP wapt.ijm.univ-paris-diderot.priv.https > fw455.ijm.univ-paris-diderot.priv.51654: Flags [.], ack 276, win 501, length 0
13:47:26.715760 IP wapt.ijm.univ-paris-diderot.priv.https > fw455.ijm.univ-paris-diderot.priv.51654: Flags [P.], seq 1:4097, ack 276, win 501, length 4096
13:47:26.719371 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [.], ack 4097, win 32768, length 0
13:47:26.720890 IP wapt.ijm.univ-paris-diderot.priv.https > fw455.ijm.univ-paris-diderot.priv.51654: Flags [P.], seq 4097:5506, ack 276, win 501, length 1409
13:47:26.723331 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [.], ack 5506, win 32063, length 0
13:47:26.725067 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [P.], seq 276:283, ack 5506, win 32063, length 7
13:47:26.725399 IP wapt.ijm.univ-paris-diderot.priv.https > fw455.ijm.univ-paris-diderot.priv.51654: Flags [F.], seq 5506, ack 283, win 501, length 0
13:47:26.725989 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [.], ack 5507, win 32063, length 0
13:47:26.726774 IP fw455.ijm.univ-paris-diderot.priv.51654 > wapt.ijm.univ-paris-diderot.priv.https: Flags [R.], seq 283, ack 5507, win 0, length 0
13:47:29.046438 IP fw455.ijm.univ-paris-diderot.priv.51613 > wapt.ijm.univ-paris-diderot.priv.https: Flags [P.], seq 1638281247:1638281283, ack 2087077311, win 8207, length 36
13:47:29.047881 IP wapt.ijm.univ-paris-diderot.priv.https > fw455.ijm.univ-paris-diderot.priv.51613: Flags [P.], seq 1:33, ack 36, win 501, length 32
13:47:29.060767 IP fw455.ijm.univ-paris-diderot.priv.51613 > wapt.ijm.univ-paris-diderot.priv.https: Flags [.], ack 33, win 8207, length 0
Kind regards,
Joel Marchand
root@wapt:/var/log#
Kind regards,
Joel Marchand
- WAPT Expert
What does the command return? on the client machine?
wapt-get register- sfonteneau
- WAPT Expert
Can you start in debug mode to see?
"c:\Program Files (x86)\wapt\waptconsole.exe" -ldebugThank you!
1st attachment: what's happening on Windows Server 2019.
2nd attachment: what's happening on Windows 10.
Best regards,
Joel
Best regards,
Joel
- Attachments
- Screenshot from 2023-10-09 13-49-39.png (71.99 KB) Viewed 8309 times
- Screenshot from 2023-10-09 13-48-10.png (70.66 KB) Viewed 8309 times
- WAPT Expert
According to the message, it's the HTTPS certificate verification that isn't working. How do I configure HTTPS verification in the console?
- WAPT Expert
When you open waptconsole.exe,
you should normally see a small wrench icon next to the server name (before clicking OK).
You will then see a "Verify HTTPS server certificate" button and below it, "Path to certificate bundle".
