[RESOLVED] Security Improvement: RDP Function
Come here to talk about your experience with Samba4, your opinion and your wishes.
stephaneB
Registration: January 8, 2020 - 3:48 PM
October 10, 2023 - 12:27
in the console, the RDP connection function (right-click -> connect via RDP) uses the machine's IP address.
However, an RDP connection via IP uses the NTLM protocol, which is less secure, and which protected accounts (Active Directory group "Protected Users") are not allowed to use.
Could the Tranquill IT team consider a modification, either to correct this or to allow the user to choose?
In the meantime, we are forced to use our own external tool, which is unfortunate.
Thank you in advance.
October 12, 2023 - 6:15 PM
Hi Stéphane,
thanks for your feedback. I've created an internal ticket and this should be fixed in a future version. In the meantime, you can use the "external tools" feature [1] to work around the problem. I'm closing the ticket for now.
Best regards,
[1] https://www.wapt.fr/fr/doc/wapt-console ... pt-console
