Removing shortcuts
Gaelds
Registration: Nov 22, 2015 - 08:37
June 6, 2016 - 09:11
I'm having trouble removing desktop icons after installing certain packages, including Adobe Reader DC and Algobox. Do you have a command that would work for these two programs?
Here are the instructions I had put in my packages so far, which do not delete anything.
remove_file(makepath(common_desktop(),'Acrobat Reader DC.lnk'))
remove_desktop_shortcut('Algobox')
remove_user_desktop_shortcut('Algobox')
Gaelds
June 6, 2016 - 10:19
Otherwise, I also have the PhotoFiltre 7 shortcut which won't delete.
June 6, 2016 - 10:59
`remove_desktop_shortcut('Algobox')` Removes the shortcut from the public Desktop folder (available to all users).
`remove_user_desktop_shortcut('Algobox')` Removes the shortcut from the current user's Desktop folder.
Therefore, it must be placed in a session setup.
For example, PhotoFiltre will create the shortcut on the user's Start menu (often the administrator).
Gaelds
June 6, 2016 - 1:35 PM
Thank you, session_setup works for Algobox and Photofiltre but the Acrobat shortcut is on the public desktop and remove_desktop_shortcut() does not work.
Gaelds
June 17, 2016 - 1:59 PM
I'm still stuck on removing the icons from the Public desktop because of:
  • Adobe reader DC
    Paint.NET
    Photofiltre 7
    Audacity
I tried with
remove_file(makepath(common_desktop(),'SHORTCOURCI.lnk'))
or remove_desktop_shortcut('Shortcut.lnk') is the same thing
