[RESOLVED] GPO agent deployment issue
Christophe
Registration: June 5, 2018 - 8:31 AM
October 24, 2023 - 08:16
I am on Windows Server 2022 with Wapt version 2.4.014143
I created a GPO that sets up a scheduled task to deploy the WAPT agent to my client workstations.
Everything worked correctly until the upgrade to version 2.4.0.14143 of WAPT.
I modified the hash as usual (--hash=5e80905b087b20818631dcbe765d89a788df2a5140bd55e5413e152d43861fd6 --minversion=2.4.0.14143 --wait=15 --waptsetupurl=http://"IP of my server"/api/v3/get_waptagent_exe/{{ip}}/waptagent.exe)
I tried running the command directly from PowerShell. Here's the error I'm getting:
WAPT version:
WAPT required version: 2.4.0.14143
Wapt agent path: C:\Users\ADMINI~1\AppData\Local\Temp\waptagent.exe
Wget new waptagent from http://172.18.50.13/api/v3/get_waptagent_exe/
Trying to reach http://"IP de mon serveur"/api/v3/get_waptagent_exe/...
Expecting hash sha256: 5e80905b087b20818631dcbe765d89a788df2a5140bd55e5413e152d43861fd6
Using proxy :
Error trying to get http://"IP de mon serveur"/api/v3/get_waptagent_exe/ : Error downloading http://"IP de mon serveur"/api/v3/get_waptagent_exe/: [EHttpSocket] THttpClientSocket.WGet:
 "IP de mon serveur":80/api/v3/get_waptagent_exe/ failed as HTTP Error 404 - Not Found... sleeping
Delete sheduled task "fullwaptupgrade"
c:\temp\waptdeploy.exe : An unhandled exception occurred at $004038EC:
Au caractère C:\Users\Administrateur\Desktop\Pb Wapt.ps1:1 : 1
+ c:\temp\waptdeploy.exe --hash=5e80905b087b20818631dcbe765d89a788df2a5 ...
    + CategoryInfo          : NotSpecified: (An unhandled ex...d at $004038EC::String) [], RemoteException
    + FullyQualifiedErrorId : NativeCommandError
Exception: Error downloading http://"IP de mon serveur"/api/v3/get_waptagent_exe/: [EHttpSocket] THttpClientSocket.WGet: "IP de mon serveur"/api/v3/get_waptagent_exe/ failed as
  $004038EC
  $00404A87
Do you have any idea where the problem comes from?
October 24, 2023 - 09:27
Hi Christophe,
have you updated the waptdeploy.exe binary in the GPO to the latest version? We've added support for {{ip}} to allow the use of the remote repository during the initial deployment.
Also, did you restart the postconf after the update?
Regards,
Christophe
October 24, 2023 - 09:48
Yes, I've updated the Waptdeploy binary.
However, what is postconf?
How do I restart it?
Christophe
October 25, 2023 - 11:07
Can anyone help me?
I'm using Windows Server 2022, and I'm not sure if I'm affected by postconf.
October 25, 2023 - 11:27
In your GPO, have you replaced waptdeploy with the latest version?
It's available on the server:
https://srvwapt.mydomain.lan/wapt/wapta ... deploy.exe
Christophe
October 25, 2023 - 11:35
Yes, I replaced it correctly.
Screenshot 2023-10-25 113435.png (21.67 KB) Viewed 8504 times
October 25, 2023 - 11:59
Christophe
October 25, 2023 - 12:12
No, unfortunately.
After accepting the risk because the self-signed certificate isn't secure, I get this message:
Internal Server Error.
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
October 25, 2023 - 1:59 PM
Do you have any secondary deposit rules?
Christophe
October 25, 2023 - 2:15 PM
Yes, indeed, I have rules based on the agents' IP addresses because I have 2 remote repositories
