[RESOLVED] GPO agent deployment issue
October 25, 2023 - 2:19 PM
I assume these are rules based on IP ranges.
Is it possible to provide us with both IP ranges?
Given the problem, I suspect the IP address given isn't a subnet IP.
Christophe
Registration: June 5, 2018 - 8:31 AM
October 25, 2023 - 2:31 PM
This is for one hub (1 depot). I have another one in Douai
Screenshot 2023-10-25 1427178.png (23.87 KB) Viewed 9437 times
Screenshot 2023-10-25 142612.png (14.99 KB) Viewed 9437 times
October 25, 2023 - 2:43 PM
It's possible to have all the rules
The one you gave seems correct
to test:
import ipaddress
ipaddress.ip_network("192.168.1.0/24")
Christophe
October 25, 2023 - 2:56 PM
Here are the others. We haven't made a rule for Arras because it's the main server
Screenshot 2023-10-25 145225.png (21.89 KB) Viewed 9434 times
Screenshot 2023-10-25 145210.png (15.56 KB) Viewed 9434 times
Screenshot 2023-10-25 145154.png (15 KB) Viewed 9434 times
Christophe
October 25, 2023 - 2:57 PM
and another one
Screenshot 2023-10-25 145241.png (19.89 KB) Viewed 9434 times
October 25, 2023 - 4:31 PM
Some of your rules are not valid:
C:\Windows\System32>waptpython
Python 3.8.18 (default, Sep 21 2023, 18:30:17) [MSC v.1929 32 bit (Intel)] on win32
>>> import ipaddress
>>> ipaddress.ip_network("172.20.166.0/20")
  File "<stdin>", line 1, in <module>
  File "ipaddress.py", line 74, in ip_network
    def _compat_range(start, end, step=1):
  File "ipaddress.py", line 1459, in __init__
    @property
ValueError: 172.20.166.0/20 has host bits set
>>> import ipaddress
>>> ipaddress.ip_network("172.20.182.0/20")
    @property
ValueError: 172.20.182.0/20 has host bits set
Using this is very convenient: https://cric.grenoble.cnrs.fr/Administr ... culMasque/
Christophe
October 26, 2023 - 12:54
Yes, there was indeed an error.
After correcting it, my GPO is working properly again.
Thank you so much for your help.
