Audit-Bitlocker
Answer
julien_esiee
Registration: Oct 25, 2023 - 3:13 p.m.
October 25, 2023 - 3:18 PM
I'd like to enable BitLocker on my laptops and I'm having trouble using the audit-bitlocker package, which, if I understand correctly, will allow me to retrieve the disk decryption key.
In setup.py, I need to specify the "decrypt_cert_list" variable, but I don't understand what format the certificates should be in—is it the filename, or something else?
Thank you for your help,
Julien
blemoigne
Registration: July 17, 2020 - 11:29
October 31, 2023 - 3:53 PM
Hello, yes, it's waiting for a list of certificate names
Answer
