This is what the command returns:
{'http': 'http://cache-etu.univ-artois.fr:3128', 'https': 'https://cache-etu.univ-artois.fr:3128', 'ftp': 'ftp://cache-etu.univ-artois.fr:3128'}
[SOLVED] Package tis-template-microsoft-store
Christophe
- Registration: June 5, 2018 - 8:31 AM
- WAPT Expert
The package will first use `
from urllib.request import getproxies`
before using the console configuration.
In your case, `'https': 'https://cache-etu.univ-artois.fr:3128'` is not valid.
It should be `'https': '//cache-etu.univ-artois.fr.
In my opinion, this value is retrieved from the machine's system variables.
Christophe
Do you know where to change this setting?
Christophe
Okay, it works.
I do indeed need to disable the proxy server in Windows settings
The download now completes correctly, but then I get this error:
CRITICAL:waptcore:Fatal error in update_package None : None:
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\connection.py", line 96, in create_connection
raise err
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\connection.py", line 86, in create_connection
sock.connect(sa)
TimeoutError: [WinError 10060] Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 353, in connect
conn = self._new_conn()
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x0C419808>: Failed to establish a new connection: [WinError 10060] Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une c
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 439, in send
resp = conn.urlopen(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='apps.microsoft.com', port=443): Max retries exceeded with url: /store/detail/9PB2MZ1ZMB1S?gl=US&hl=en-US (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0C419808>: Fa
iled to establish a new connection: [WinError 10060] Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu'))
File "C:\Program Files (x86)\wapt\common.py", line 8546, in call_python_code
hookdata = hook_func()
File "C:\Users\ADMINI~1\AppData\Local\Temp\wapt-20231025-15434000000.tmp\dsi-template-microsoft-store-app_0-56_windows_10.0_PROD\update_package.py", line 203, in update_package
bs_name = bs_find(microsoft_store_url + "?gl=US&hl=en-US", "meta", "property", "og:title", allow_redirects=True)["content"]
File "<string>", line 102, in bs_find
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='apps.microsoft.com', port=443): Max retries exceeded with url: /store/detail/9PB2MZ1ZMB1S?gl=US&hl=en-US (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0C419808>:
Failed to establish a new connection: [WinError 10060] Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu'))
raise err
sock.connect(sa)
conn.connect()
File "C:\Program Files (x86)\wapt\common.py", line 8550, in call_python_code
raise e
Failed to establish a new connection: [WinError 10060] Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu'))-
Christophe
Before this error, I get this message and I don't know what to do (except click "OK")
- Attachments
- Screenshot 2023-10-25 1556267.png (14.33 KB) Viewed 10606 times
- WAPT Expert
here :
Your new message apparently doesn't work without a proxy
- Attachments
- Capture.PNG (29.14 KB) Viewed 10594 times
Christophe
I have no information regarding proxy settings in the "environment variables"
- Attachments
- Screenshot 2023-10-26 080720.png (50.11 KB) Viewed 10586 times
Christophe
So, I added the proxy settings for HTTP and HTTPS to the Windows environment variables.
Now, with `getproxies`, I have the correct settings.
However, it still doesn't work.
We observed that the software downloads correctly through the proxy at the address "store.rg-adguard.net".
Once the download is complete, we ran `netstat` and noticed a connection on two IPs (see screenshot) that doesn't go through our proxy. That's why I'm getting an error.
- Attachments
- Screenshot 2023-10-26 151719.png (28.28 KB) Viewed 10556 times
- Screenshot 2023-10-26 151623.png (5.5 KB) Viewed 10556 times
- WAPT Expert
Thank you for your feedback.
I've just pushed a new version of the package to the store.
There was indeed a proxy issue; it wasn't working for all calls.
I also prioritized the console proxy configuration over the system one.
Christophe
Indeed, with this new version of the package, the download completes correctly.
I manage to create my package entirely, but it doesn't install on the PC.
I think I'm forgetting to do something, but what?
- Attachments
- Screenshot 2023-10-27 083418.png (20.09 KB) Viewed 10539 times
- Screenshot 2023-10-27 083448.png (13.13 KB) Viewed 10539 times
