We are able to use the WAPT service and self-service without Active Directory.
This works by creating a local user group with the local user of the workstation as a member and creating a self-service rule based on the same group name.
I wanted to know if with WAPT it is possible to first create a local user group on all the workstations in our network and then either add the current user who runs the agent to it, or, with a second package, add the user of our choice.
Thank you in advance,
Dany,
IT Department
, GIP RENATER
Using WAPT and self-service without AD
- WAPT Expert
Hi,
it seems a bit far-fetched, but yes, it's possible.
Otherwise, I have two tips that might help:
Tip for Windows: all users are members of the "Users" group.
The other tip is that you can also directly use usernames instead of group names in the self-service rules,
if that helps...
if that helps...
