Hello
, I have a quick question. I'm creating packages for my company that aren't available on the WAPT store (TinyCAD is created, Zimbra ZCO is being created). I figured I'm probably not the only one using them.
How can I/who should I send them to so they're available to everyone on the WAPT store?
Thanks
[RESOLVED] Offering packages for the store
Good evening Vincent38.
Great, you're on the Enterprise version, so it will be easier to answer you.
As you may have noticed, and in order to add even more value to the Enterprise version and save admins even more time (which is the ultimate goal), more and more packages are marked "Restricted" in the Tranquil IT store and are for the exclusive use of Enterprise version customers.
The strategy will be to accept packages that WAPT admins offer us (not all of them, unfortunately), refine them to bring them up to the state of the art in WAPT coding, integrate them into the Luti CI/CD pipeline (https://luti.tranquil.it), and finally allow you to retrieve the package directly from your WAPT console for deployment across your network.
Currently, there is no clear circuit yet to allow the dropping of a package; this is a feature that could arrive quite quickly as it relies on the same authentication method that you currently use to collect "Restricted" packages from the store.
