[SOLVED] Problem with install_msi_if_needed and msix file
t.heroult
Registration: December 8, 2020 - 10:13 AM
November 9, 2023 - 3:24 PM
Good morning
I want to develop a package for the new MS-TEAMS which is provided as msix.
But when I try a simple install_msi_if_needed('MSTeams-x86.msix') in pyscripter, I get this output:
2023-11-09 15:13:13,714 CRITICAL Fatal error in install script: MSIError: open failed:
  File "C:\Program Files (x86)\wapt\common.py", line 4083, in install_wapt
  File "c:\waptdev\ln-msteams-x86_0.0.0_Windows_PROD\setup.py", line 16, in install
  File "C:\Program Files (x86)\wapt\common.py", line 4033, in new_func
    return func(*args, **kwargs)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1379, in install_msi_if_needed
    key = get_msi_properties(msi)['ProductCode']
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 2825, in get_msi_properties
    db = msilib.OpenDatabase(msi_filename, msilib.MSIDBOPEN_READONLY)
_msi.MSIError: open failed
FATAL ERROR : MSIError: open failed
Exit code:  3
Any idea what's going on?
Consoles: Windows 10 & 11
Infrastructure: Windows
November 9, 2023 - 5:50 PM
Hi Thomas,
it seems to me that the msix format has very little to do with the msi format. The msilib library, which is used underlying the install_msi_if_needed function, doesn't apparently handle it.
For now, we'll have to run it with something like run(), I believe...
t.heroult
November 10, 2023 - 09:08
I understand, but what's inconsistent is that from the console, I launched the new package wizard, the first option offering msi, msix, and exe, and after selecting msix, PyScripter opens with the `install_msi_if_needed` line already created.
This needs to be reviewed if the function can't handle msix files.
t.heroult
November 10, 2023 - 10:54
So, I don't see how to install MSIX with WAPT.
The simplest way would normally be to use PowerShell with Add-AppxPackage, except that this operation isn't possible with the LOCAL SYSTEM account used by WAPT...
November 10, 2023 - 11:01
Indeed, I just saw that msix is ​​hardcoded in waptconsole
We're going to remove the reference; it's a historical error
In the meantime, you can try something like this:
    filecopyto('MyApp.msix','c:\MyApp.msix')
def session_setup():
    run(r'powershell Add-AppPackage -path "c:\MyApp.msix"')
t.heroult
November 10, 2023 - 11:42
Hi Simon
, as I mentioned in my previous comment, it's not working.
At least, it works in PyScripter since it's launched with my account, but the WAPT agent runs with the SYSTEM LOCAL account, which doesn't have permission to run "PowerShell Add-AppxPackage". This is forbidden by Windows, and the same applies to Add-AppPackage itself.
November 10, 2023 - 12:35
But in my example it's a session_setup, so not a system, so it doesn't work either?
t.heroult
November 10, 2023 - 12:41
I don't know what the result would be in session_setup...
I'll test it and see.
More later!
t.heroult
November 10, 2023 - 3:04 PM
Negative feedback, nothing happens.
The command used is: powershell Add-AppPackage -Path "C:\Software\bin\MSTeams-x64.msix"
Launched by session_setup: nothing happens
Launched from a PowerShell window (standard user): it works...
    cmd = 'powershell Add-AppPackage -Path "C:\Logiciels\bin\MSTeams-x64.msix"'
    run(cmd)
November 10, 2023 - 3:42 PM
Hmm, the 'r' before the string?
Or should I just use the full path:
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe
