I'm creating this topic for two minor everyday production issues:
- Is it possible to integrate an uptime section into the general section for workstations? Perhaps a column in the inventory console?
This would be particularly useful as it would significantly reduce the need to deduce when PCs were last restarted.
- It's not possible to block the installation of certain applications selected by default:
For example, I have a list of packages that install on all PCs in the domain (including TightVNC Server), but for the admin OU, I want TightVNC Viewer. Consequently, the admin PCs are always getting errors related to this.
Thank you in advance.
Have a good day.
[RESOLVED] Post Uptime
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
- WAPT Expert
In the hardware inventory you have "last_boot_uptime"
This corresponds to the date of the machine's last startup; you can drag the value into the columns to get it for all machines
This specific case is indeed not being handled intentionally to avoid falling into an overly complex mechanism.Marceld wrote: ↑Nov 10, 2023 - 12:49 PM - It's not possible to block the installation of certain applications selected by default:
For example, I have a list of packages that install on all PCs in the domain (including, for example, TightVNC Server), but for the admin OU, I want TightVNC Viewer. As a result, the admin PCs are always getting errors on this point.
You can use a metapackage if you wish:
if 'adm' in hostname:
WAPT.install('Tight-VNC-server')
WAPT.install('tis-Tight-VNC-Viewer')
