[SOLVED] Problem with install_msi_if_needed and msix file
Test result: it only works if the user is an admin of the machine.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
- WAPT Expert
On a forum obviously it indicates that you have to use Add-AppxProvisionedPackage
Currently the installation of an MSIX app to all users does require the use of the Add-AppxProvisionedPackage PowerShell cmdlet, or the use of the DISM parameter /add-appxprovisionedpackage.
https://learn.microsoft.com/en-us/power ... escription
Good call on the cmdlet!
However, this cmdlet must be executed with an admin account, but for this, the LOCAL SYSTEM account is authorized.
Here is the complete setup.py file for those who are interested:
Reminder :
- "-Online" to integrate with the current Windows installation
- "-SkipLicense" otherwise the cmdlet fails because it normally requires a license file which is not provided.
Thanks Simon, thanks to you, I'm going away for the weekend having finished this!
Have a great weekend!
For those who are interested:
x86: https://go.microsoft.com/fwlink/?linkid=2196060
x64: https://go.microsoft.com/fwlink/?linkid=2196106
PackageName = "MSTeams_23285.3604.2469.4152_x64__8wekyb3d8bbwe"
print("Installation du Nouveau Teams")
cmd = r'powershell Add-AppxProvisionedPackage -Online -SkipLicense -PackagePath "MSTeams-x64.msix"'
run(cmd)
cmd = r'powershell Remove-AppxPackage -AllUsers %s' %(PackageName)
run(cmd)
The package will soon be available on the Store and is already available on the Testing repository: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Regards,
Jimmy
Regards,
Jimmy
