Hello
, yes, indeed, since "manual" is selected, the existing configuration is overwritten because it's "manual".
We had planned a multi-configuration mode which is available, so I can offer you another solution:
In /opt/wapt/conf/waptserver.ini, add:
auto_create_waptagent_from_config=True.
Then create your two initial configurations: https://www.wapt.fr/fr/doc/wapt-configu ... se-feature
Default and another one.
Then regenerate an agent.
On the server, you will then have two executables in /var/www/wapt:
ls -l /var/www/wapt/*2.4*.exe
. Each executable has a different configuration depending on the initial configuration. (Do not change the file name.)
HTTPS problem with WAPT 2.3 or 2.4
- WAPT Expert
- WAPT Expert
I just added in Wapt version 2.5 the ability to have the download link directly from the web interface.
This will only be displayed if `auto_create_waptagent_from_config=True`.
- Attachments
- Capture.PNG (7.29 KB) Viewed 10699 times
Good evening lfimd,
We are currently working on the 2.4 to 2.5 migration documentation, which is complex but not simple, alongside client projects that are taking up a significant amount of time.
It will be completed soon, but not too soon, because the best stew is the one that has been cooked thoroughly.
