tis-arduino package in French
Gaelds
Registration: Nov 22, 2015 - 08:37
December 4, 2023 - 2:15 PM
is it possible to install Arduino in French directly, or to configure it after installation? I can't find anything in the registry...
blemoigne
Registration: July 17, 2020 - 11:29
December 4, 2023 - 3:38 PM
Here is a good idea (source: https://support.arduino.cc/hc/en-us/art ... rduino-IDE):
you can edit the preferences.txt file directly.
Close Arduino IDE.
Open the Arduino15 folder.
Open preferences.txt.
Find the editor.languages.current line.
Edit the value to read editor.languages.current=en.
Save the file.
Open Arduino IDE to see the changes.
Gaelds
December 4, 2023 - 3:46 PM
I couldn't find a preferences.txt file in the Arduino installation folder. But I just discovered that it's located in C:\Users\<user> \.arduinoIDE\arduino-cli.yaml which is modified.
I wanted to try this code:
def session_setup():
    ## Changement de langue du logiciel vers français
    settings_arduino = makepath(user_home_directory(),'.arduinoIDE','arduino-cli.yaml')
    with open(settings_arduino, "rt") as file:
        x = file.read()
    with open(settings_arduino, "wt") as file:
        x = x.replace("locale: en", "locale: fr")
        fin.write(x)
But the ".arduinoIDE" folder is only created after the software is launched for the first time, so session_setup won't do anything... And what's more, my code is incorrect; I end up with an empty arduino-cli.yaml file :)
2023-12-04 15_43_10-C__Users_informatique.DS_.arduinoIDE_arduino-cli.yaml - Notepad++ [Administrator.jpg
2023-12-04 15_43_10-C__Users_informatique.DS_.arduinoIDE_arduino-cli.yaml - Notepad++ [Administrator.jpg (51.38 KB) Viewed 26443 times
Benoit
Registration: June 26, 2023 - 11:52
December 7, 2023 - 10:47
Why not use a while loop? For example, something like this:
import os
    try : # pour la gestion des erreurs
        file_exist = False # initialise la variable file_exist
        while not file_exist: # boucle qui recommence tant que  file_exist n'est pas vrai
            if os.pah.exists(settings_arduino): # vérifie si le fichier de configuration existe
                    x = file.read()
                    fin.write(x)
                file_exist = True
                print("Le fichier arduino-cli.yaml a été mis à jour )
            else :
                file_exist = False # renvoi false à la variable file_exist sir le fichier n'éxiste pas
    except Exception as e:
        print(f"L'erreur suivante s'est produite : {e}")
As for modifying the configuration file, I preferred to use a third-party script in AutoIt:
#include <FileConstants.au3>
#include <File.au3>
#include <StringConstants.au3>
Local $file_path = @UserProfileDir & "\.arduinoIDE\arduino-cli.yaml"
Local $yaml_file = @UserProfileDir & "\.arduinoIDE\arduino-cli.yaml"
Local $proxy_line = "proxy: ********************"
Local $file_exists = False
While (Not $file_exists)
    If FileExists($file_path) Then
        $file_exists = True
        ; Boucle pour tester si le proxy est présent
        While StringInStr(FileRead($yaml_file), $proxy_line) = 0
            ; Ajout du proxy
            FileWriteLine($yaml_file, "network:")
            FileWriteLine($yaml_file, "    proxy: **************************")
            Sleep(1000) ; Attendre 1 seconde
        WEnd
    Else
    EndIf
WEnd
Regards,
December 12, 2023 - 12:11
Hello everyone,
@gaelds I tested modifying the arduino-cli.yaml file automatically, but it doesn't seem to have any impact (but I can confirm that this file is indeed modified when there's a change in the GUI, but there are lots of other things that are copied at the same time too...
@Benoit, using autoit is not recommended; the Python part allows you to handle exceptions and other scenarios.
@Benoit, using a while loop is not recommended because it's more error-prone (in case of exceptions, etc.)
After spending half an hour with this software, I'm rather appalled by the poor (or nonexistent) packaging. The system-wide installation is a joke; the software copies everything into the user directory on first launch, a bit like:
  • a little bit in %HOMEPATH%/.arduinoIDE
  • a little bit in %APPDATA%\roaming\arduino IDE
  • a little bit in %APPDATA%\roaming\arduino-ide
  • a lot in %APPDATA%\local\Arduino15 (>400MB)
  • a lot in %APPDATA%\local\arduino-ide-updater (>130MB, just for the updater which we didn't originally want...)
And of course it doesn't work in AppLocker or SRP environments (as some say, "security is for the weak", they've clearly never seen ransomware at Arduino...).
There is no global configuration file, and the driver pre-loading is unreliable to say the least; blocking automatic updates should be included in a future version...
I have a colleague at the office who installed it on his son's machine yesterday (a recycled PC), the installation and launch took more than ten minutes, he went straight back to the latest version 1.x.
In short, I think Arduino does not want to be deployed in schools.
Geoffroy
Registration: June 28, 2022 - 3:34 PM
December 18, 2023 - 10:56 AM
I can confirm, our school uses it and we had to implement a GPO. A real nightmare...
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
December 18, 2023 - 3:38 PM
Hi Geoffroy,
if this is a GPO for the initial Arduino 2 configuration, could you explain how you set up your GPO? Perhaps we could use session_setup()? I haven't been able to do it consistently, so if you have the details of the steps involved, I'd appreciate it :-) !
Best regards,
olaplanche
Registration: January 26, 2017 - 11:11
March 6, 2025 - 5:11 PM
I'm sharing my SRP-compatible arduino-ide package, with auto-update disabled and French as the default language:
Prerequisites:
* Configure the software in French for the first time, then copy the folder below to the root of the package:
C:\Users\%username%\AppData\Roaming\arduino-ide\Local Storage\leveldb
* Create an unrestricted SRP on the folder "%AllUsersProfile%\Arduino15"
import platform
bin_name_string = 'arduino-ide_%s_Windows_64bit.msi'
    # Declaring local variables
    bin_name = bin_name_string % package_version
    all_user_data = makepath(programdata,'Arduino15')
    # Installing the software
    install_msi_if_needed(bin_name,
        properties='/qn ALLUSERS=1',
        timeout=1200
    print('Restricting permissions on %s' % all_user_data)
    if not isdir(all_user_data):
        mkdirs(all_user_data)
    run(r'icacls "%s" /t /grant *S-1-5-21-3299883279-2723331061-yyyyyyyyyy-xxxx:(OI)(CI)M' % all_user_data) # groupe AD ELEVES (Get-ADGroup -Identity ELEVES | select Name, SID)
    run(r'icacls "%s" /t /grant *S-1-5-21-3299883279-2723331061-yyyyyyyyyy-xxxx:(OI)(CI)M' % all_user_data) # groupe AD PROFESSEUR (Get-ADGroup -Identity PROFESSEUR | select Name, SID)
    print('Add Windows Firewall rules')
    add_netfirewallrule(r"Arduino IDE", r"C:\program files\Arduino-IDE\Arduino IDE.exe", profile="Domain")
    add_netfirewallrule(r"mdns-discovery", r"C:\ProgramData\arduino15\packages\builtin\tools\mdns-discovery\1.0.9\mdns-discovery.exe", profile="Domain")
    # Installing Arduino IDE user settings
    print('Copying Arduino IDE user settings to %s' % all_user_data)
    copytree2("leveldb","%s\leveldb" % all_user_data)
    import tempfile
    # Set Arduino CLI language fr and librairies/data/downloads paths
    pathfile = makepath(tempfile.gettempdir(),'arduino-cli.yaml')
    currentuser = get_current_user()
    configpath = makepath(r'c:\users',currentuser,'.arduinoIDE')
    datafile = r"""board_manager:
  additional_urls: []
daemon:
  port: "50051"
directories:
  builtin:
    libraries: C:\ProgramData\Arduino15\libraries
  data: C:\ProgramData\Arduino15
  downloads: C:\ProgramData\Arduino15\staging
  user: C:\Users\%s\Documents\Arduino
library:
  enable_unsafe_install: false
locale: fr
logging:
  file: ""
  format: text
  level: info
metrics:
  addr: :9090
  enabled: true
output:
  no_color: false
sketch:
  always_export_binaries: false
updater:
  enable_notification: false
""" % currentuser
    fichier = open(pathfile, "w")
    fichier.write(datafile)
    fichier.close()
    mkdirs(configpath)
    filecopyto(pathfile,configpath)
    remove_file(pathfile)
# Disable Update Notification
    pathfile = makepath(tempfile.gettempdir(),'settings.json')
    datafile = r"""{
  "window.titleBarStyle": "native",
  "arduino.checkForUpdates": false
    fichier.close()
    mkdirs(configpath)
    # Set Arduino IDE language fr
    leveldbpath = makepath(r'c:\users',currentuser,'AppData','Roaming','arduino-ide','Local Storage','leveldb')
    if not isdir(leveldbpath):
        mkdirs(leveldbpath)
    copytree2("%s\leveldb" % all_user_data,leveldbpath)
    print('Uninstalling all_user_data')
    remove_tree(makepath(programdata,'Arduino15'))
    print('Uninstalling Windows Firewall rules')
    remove_netfirewallrule("Arduino IDE")
    remove_netfirewallrule("mdns-discovery")
Sincerely
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
vcardon
March 6, 2025 - 7:30 PM
Olivier, when are you coming to work with us? :D
olaplanche
March 7, 2025 - 2:01 PM
When I get tired of my current position, I'll let you know :D
Answer
