[SOLVED] Improvement computer not seen since 30 days
Share your SQL query ideas for reporting in the WAPT Enterprise console here
Gaetan
Registration: August 8, 2019 - 10:16
December 6, 2023 - 9:26 AM
I suggest adding sorting by PC name to the existing query, which would give:
SELECT computer_name, computer_fqdn, productname, computer_ad_ou, wapt_version, last_seen_on , TO_DATE(last_seen_on,'YYYY/MM/DD'), uuid
FROM hosts
where TO_DATE(last_seen_on,'YYYY/MM/DD') < CURRENT_DATE - INTERVAL '30< DAYS'
order by hosts.computer_name ASC
December 8, 2023 - 3:47 PM
Hi Gaëtan,
how are things going up there in the southwest?
Thanks for the update. We've updated the SQL query template internally; it should be updated online soon if it isn't already. :-)
See you soon,
