We've upgraded our server to a new license, so we're currently running on two machines. The vast majority of our network and its agents are still pointing to the old server. The WAPT agent is distributed via GPO.
After testing, it seems necessary to manually uninstall the old agent before deploying the new one. Following this, the client connects correctly to the new console.
Is there a solution that would allow us to avoid doing this on each machine individually and facilitate this migration?
[RESOLVED] Server change
- WAPT Expert
Hi Yannick,
old server version, new server version? See the forum rules. Changing the server configuration shouldn't be a problem. Are you using dynamic configuration packages?
Hello Denis,
Thank you for your reply.
I should have specified that these are indeed two separate servers. Both are running version 2.4.0.14143 on Ubuntu Linux, with the same version for the agent and wapt deploy.
What do you mean by dynamic configuration packages?
- WAPT Expert
Hi Yannick,
yes, it's clearer with the additional information.
waptdeploy relies on the agent version, so since it hasn't changed, it doesn't deploy the new one. It's possible to add a --force parameter to waptdeploy in your GPO, however, this will reinstall the agent every time the machine restarts, so it should only be used for a short time.
Another way is to put a package on your old server that installs your new agent. This will force the switchover.
Regards,
Regards,
- WAPT Expert
Hello Yannick,
You can retrieve the xxx-waptupgrade package from your new server and import it onto your old server, setting the default mode to force=True by modifying the following line in setup.py:
force = True
# if you want to modify the keys depending on environment (win32/win64... params..)
