[SOLVED] FATAL ERROR: AttributeError: 'NoneType' object has no attribute 'package
Answer
Geoffroy
Registration: June 28, 2022 - 3:34 PM
January 4, 2024 - 9:24 PM
Hello everyone.
First of all, a happy and prosperous new year to everyone.
Environment :
Server: WAPT Enterprise 2.4.0.14080 on Debian
Consoles: Windows 10 & 11
Park: Windows
We have a package that works perfectly across our entire network, however on one PC we get this error.
 CRITICAL Package questeducation-Microsoft-Visual-Studio-Community-QuestEducation [x64_fr_PROD] not installed due to errors : TypeError: stat: path should be string, bytes, os.PathLike or integer, not NoneType
Results :
 === install packages ===
  questeducation-Microsoft-Visual-Studio-Community-QuestEducation [x64_fr_PROD] | questeducation-Microsoft-Visual-Studio-Community-QuestEducation (17.7.34031.279-4)
FATAL ERROR : AttributeError: 'NoneType' object has no attribute 'package'
If you have a lead.
I'm going to try a few things on the computer and I'll keep you informed if the problem is solved
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
January 5, 2024 - 10:32
Hello Geoffroy,
Happy New Year 2024!
It seems that in your package you're calling a filesystem path that doesn't exist on the machine... Do you have the contents of setup.py? Could the machine be running a 32-bit system?
Regards,
Geoffroy
January 8, 2024 - 3:26 PM
Hello Denis,
The PC is indeed x64-based; here is the Setup.py file
    # Declaring local variables
    # Installing the software
    print("Installing: vs_setup.exe")
    install_exe_if_needed('vs_setup.exe', timeout=3000,
    silentflags='--nocache --wait --noUpdateInstaller --noWeb --add Microsoft.VisualStudio.Workload.NativeDesktop;includeRecommended;includeOptional --add Microsoft.VisualStudio.Workload.NativeGame;includeRecommended;includeOptional --add Microsoft.VisualStudio.Workload.NativeMobile;includeRecommended;includeOptional --add Microsoft.VisualStudio.Workload.ManagedGame;includeRecommended;includeOptional --quiet --norestart',
    import shutil
    src_path = 'Visual Studio 2022.lnk'
    dst_path = "C:\ProgramData\Microsoft\Windows\Start Menu\Programs"
    shutil.copy2 (src_path, dst_path)
    print('Copied')
    import shutil
    src_path = 'Visual Studio Installer.lnk'
    print('Copied')
    import shutil
    dst_path = "C:\\Users\\Public\\Desktop"
    print('Copied')
jpele
Registration: March 4, 2019 - 12:01
January 10, 2024 - 10:51
Processed via WAPT Support.
Geoffroy
January 10, 2024 - 11:35
After contacting support, they didn't clearly explain the problem.
On my end, I tried several installations via the console and command line on the machine, using something like
`wapt-get install nondu package --force`. It re-downloads the package, but not completely, leaving a partial file in the cache folder.
I had to download the package separately and run the installation for it to work.
I'm not really explaining the problem, especially since it only affects one machine.
Answer
