The console cannot find the draw.io update even though it is present in the Wapt store
Answer
tux
Registration: Sep 05, 2023 - 09:44
January 17, 2024 - 1:24 PM
When I go to https://wapt.tranquil.it/store/fr/tis-drawio, I see a version of tis-drawio 22.1.18-4 x64 for all Windows
. The version in my console is 22.0.2 x64 for Windows. It comes from the Wapt store.
The console doesn't display the drawio package in red, and I don't have the option to right-click and select "Update from store."
It's as if the package has lost its connection to the Wapt store.
For other packages, the console correctly displays the updateable packages in red, and I can launch the update from the store.
Do you have any idea how to fix my problem?
Sébastien
Wapt Enterprise Edition 2.6.1.17765
WAPTConsole Enterprise on Windows
WAPT Server on Debian 12
January 17, 2024 - 1:55 PM
this is a problem with Wapt 2.4; the console only sees packages tagged Linux and not Debian, for example.
We just fixed this in Wapt version 2.5.
- Simon
tux
January 17, 2024 - 2:14 PM
thank you for the feedback.
I hadn't noticed that version 2.5 was released.
I just looked at the documentation, and upgrading the server from 2.4 to 2.5 doesn't seem complicated.
This will be our first version upgrade.
Once the server is updated, will the agents and console update automatically?
Answer
