[RESOLVED] Session_setup() at each session start
Typhoon
Registration: Nov 9, 2022 - 09:40
January 22, 2024 - 4:19 PM
As part of package development, we would need code to run every time a session is opened.
We are currently using version 2.4.0141143
Knowing that the execution information for session_setup() is recorded in waptsession.sqlite, we tried to delete this record
def session_setup():
      import sqlite3
      db_path=makepath(application_data,"wapt","waptsession.sqlite")
      con = sqlite3.connect(db_path)
      cur = con.cursor()
      cur.execute("delete from wapt_sessionsetup where package='bpi-FontsInstaller'")
      con.close()
But that tells us that the database is already open.
Is there a way to delete this record so that the Session_Setup() code executes again at the next session opening?
Is there another way to do it?
Thanks in advance 🙏😊
January 22, 2024 - 4:34 PM
The simplest way is to add a
"RETRY" return statement
. Since the code isn't working, the code will be executed each time session_setup.py is restarted.
However, in this type of situation, it might be simpler to do it in a separate session startup script. It depends on your needs.
Typhoon
January 22, 2024 - 5:36 PM
Thanks for the quick reply.🥳
The suggestion to use a "RETRY" return is interesting;
we'll test it.
Our fundamental problem is that some users need to be able to install any font without administrator privileges. The idea is to create a package that scans a directory where users can place their fonts for installation.
