[SOLVED] Bug after migrating to 2.5?
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
January 25, 2024 - 09:48
Hello everyone,
I just completed a major
Debian 10 -> 11 -> 12
. Everything went smoothly.
Then I migrated to version 2.5.2.15207.
Now the computers are gradually connecting after the 2.5 update, which is great!
However, if I go directly to the server at https://waptsrv.xxx.xx,
I used to be able to download either the agent or the console.
Now it asks me for a password.
Any idea what could be causing this problem?
Thanks!
Screenshot 2024-01-25 094630.png (8.28 KB) Viewed 6601 times
January 25, 2024 - 10:38
Hello
, yes, this is new. We were often criticized for displaying too much information on the Wapt webpage, so now we require authentication (the same as the console).
If you prefer the previous method, you can add the following to /opt/wapt/conf/waptserver.ini:
login_on_homepage=False
guigeek
January 25, 2024 - 11:01
Oh great! Thank you
