[SOLVED] Problem with package tis-microsoft-onenote 16001.14326.21738.0-62
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
cefinformatique
Registration: May 26, 2023 - 2:25 p.m.
January 25, 2024 - 4:05 PM
When installing this package (the previous version works without any problems) on a Windows 10 Pro 22H2 PC, I get the following error:
  File "C:\Program Files (x86)\wapt\common.py", line 4074, in install_wapt
  File "C:\Windows\TEMP\wapt4c7ye69o\setup.py", line 31, in install
NameError: name 'get_host_architecture' is not defined
January 25, 2024 - 4:24 PM
Hi Marc,
which version of Wapt? (see forum rules)
cefinformatique
January 25, 2024 - 4:31 PM
Sorry.
This is version 2.3.0.13516
January 26, 2024 - 12:31
Hello Marc,
Thanks for your feedback. The get_host_architecture() function was moved to setuphelpers with version 2.4... The package should have taken this into account (or specified that the minimum version of wapt is 2.4).
To resolve the issue, you can add the function below to your setup.py file, above the `def install()` function
def get_host_architecture():
    if isARM64():
        return "arm64"
    elif isARM():
        return "arm"
    elif is64():
        return "x64"
    elif is32():
        return "x86"
I encourage you to upgrade to version 2.5, it includes quite a few fixes and the upgrade is fairly simple.
