[SOLVED] version in registry does not match requirements of min_version
cefinformatique
Registration: May 26, 2023 - 2:25 p.m.
January 3, 2024 - 1:54 PM
I created a package to deploy software (already installed on client machines) version 23.1.0.4
Here is the setup.py file for my package:
    softname ='AWCLIENTSQL'
    listAW=installed_softwares(softname)
    if listAW == softname:
        print("Mise a jour de DiaClientSQL")
        install_exe_if_needed('DiaClientSQLInstall.exe',
            silentflags='/Silent',
            key='AWCLIENTSQL',
            remove_old_version=True
            key='AWCLIENTSQL'
        filecopyto(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ACDSuite\DiaClient SQL.lnk',r'C:\Users\Public\Desktop')
Once the package is deployed, I get the following error in 80% of cases:
waptutils.EWaptSetupException: Fatal error: Setup DiaClientSQLInstall.exe has been executed and key AWCLIENTSQL has been found in the registry, but version in registry does not match requirements of min_version=23.1.0.4
If I manually restart the update, it will eventually apply correctly after several attempts.
The version installed before the update via WAPT was 23.1.0.2
What can I do to avoid this problem?
January 3, 2024 - 3:24 PM
No min_version argument is passed to install_exe_if_needed
So the function does this:
if min_version is None:
    min_version = get_product_props(exe)['version']
And retrieves the version number specified in the file properties.
In your case, it probably isn't good
The best approach would be to add a min_version argument with the version number associated with the AWCLIENTSQL key
cefinformatique
February 13, 2024 - 1:36 PM
I'm reopening this topic because, during a recent software update, I correctly entered the "min_version" value, but this didn't resolve the issue.
I've found the cause: During program installation, the old version isn't uninstalled. Because the installation returns an error code of 0 before updating the version number in the Windows registry, the WAPT package compares its version number with the old number still stored in the registry.
Therefore, I need to make the WAPT package wait (approximately 20 seconds) at the stage between the end of the installation and the version number check in the registry to resolve this problem.
Is this possible?
cefinformatique
February 14, 2024 - 2:34 PM
I solved my problem by using the WinReg module to delete the software's registry key before installation. It's a bit of a hack, but it works!
import winreg
r"""
uninstallkey = ['AWCLIENTSQL']
    killalltasks(control.get_impacted_process_list())
    listFULL=installed_softwares(softname)
    listAW=listFULL[0]['key']
        # Define the registry key path
        key_path = r"SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall"
        # Open the registry key for deletion
        try:
            with winreg.OpenKey(winreg.HKEY_LOCAL_MACHINE, key_path, 0, winreg.KEY_ALL_ACCESS) as registry_key:
                winreg.DeleteKey(registry_key, "AWCLIENTSQL")
                print("Registry key deleted successfully.")
        except FileNotFoundError:
            print("Registry key not found.")
        except PermissionError:
            print("Permission error. Run the script with administrative privileges.")
        except Exception as e:
            print(f"An error occurred: {e}")
            key=softname,
            remove_old_version=True,
#            min_version=control.get_version()
        print("Installation de DiaClientSQL")
            key=softname,
February 15, 2024 - 4:25 PM
Hi Marc,
thanks for the feedback!
